instrument cluster removal on 98 V70XC
Old Dec 3, 2009 | 05:33 PM
trooperone's Avatar
Talking instrument cluster removal on 98 V70XC
I am needing to change some bulbs in my 98 V70XC's instrument cluster. I have removed clusters from our 850's before, so am pretty familiar with those, but this one, I am sure, is a different procedure.
Does anyone know the procedure to remove the cluster (or at least be able to access the back where the bulbs are) on this model?
As always...thanks for the help!!
Old Dec 3, 2009 | 07:15 PM
It is pretty much the same as the 850. There is just a few different screws.
Old Dec 3, 2009 | 08:33 PM
trooperone's Avatar
OK--good! On the 850's, you could get by with just unloosening the driver's side and about mid-way across the dash and almost "twisting" it up enough without doing anything on the pass. side. Would that still hold true on this one, or do I need to unhook the pass. side airbag, etc?
Old Dec 3, 2009 | 08:50 PM
That should work but let it be known that you can break the dash part where the top locks on in the front.
But yes it should work.
Old Dec 3, 2009 | 11:31 PM
trooperone's Avatar
Thanks tech!! I will try it on this one when I can get it inside where it is MUCH warmer....and take it slowly with it.
rspi
Aug 13, 2013 07:40 PM
rspi
cn90
Apr 24, 2013 01:18 AM
volvo5volvo
May 29, 2012 05:46 AM
Volvo V70R
May 23, 2007 02:49 PM
