Oil in and around the intercooler hose
Old Jun 17, 2010 | 02:50 PM
family XC70's Avatar
Default Oil in and around the intercooler hose
I was taking the fan and Rad out to be able to do some A/C work and noticed the intercooler hose has a good bit of oil around it and some inside it. There are no symptoms whatsoever that I can tell from this. Is this normal or something that I should be concerned about before I put it back together? The car does not smoke at all that I have noticed.
Old Jun 17, 2010 | 06:28 PM
SVTfocusO3's Avatar
This is usually normal if not excessive, have your oil trap checked.
Old Jun 17, 2010 | 09:00 PM
Would I be checking to see if the oil trap is clogged? if so, are there any sure fire ways to tell without taking it all apart?
Old Jun 18, 2010 | 07:04 AM
SVTfocusO3's Avatar
Well yes, if you have pressure at your dipstick, then it is clogged, but a gauge that Volvo uses measures small amounts of vacuum, you may just stop in and ask them, takes 2 secs.
vjaneczko
Jun 7, 2010 04:08 PM
Somthngfrce
Sep 3, 2009 10:19 AM
wayne73
Aug 17, 2008 09:43 AM
ciao-rich
Jun 13, 2008 05:01 PM
Cornfed
Apr 27, 2006 08:55 PM
