OIL COOLER HOSE 2001 XC70 routing
Old May 28, 2010 | 09:39 PM
kevink's Avatar
Default OIL COOLER HOSE 2001 XC70 routing
can anyone here tell me where to find routing information for the transmission oil cooler hose. we noticed it was dragging the ground on the drivers side (US). it was inserted upward into the engine compartment on the passenger side. neither end was connected.
also, where to check the transmission fluid.
Old May 28, 2010 | 10:45 PM
SVTfocusO3's Avatar
the lines goes to either the lower radiator, by the hose, or up above it on the radiator, under the hood. the dipstick for it is hidden on the trans, under the radiator hose routing from under the hood, its yellow.
Old May 31, 2010 | 09:16 PM
kevink's Avatar
Default thanks
thank you. that helps.
Old Jun 1, 2010 | 11:16 AM
SVTfocusO3's Avatar
Ok, let me know if you need anymore help.
Old Jun 4, 2010 | 04:07 PM
kevink's Avatar
Default troubled transmission
This transmission continues to be a problem. It is the the typical 2001 Volvo transmission issue.
does anyone know if it is possible to replace the automatic transmission with a manual transmission?
are there known issues with Volvo manual transmissions?
alfaromeo
Jul 25, 2015 01:02 PM
kazbah
Aug 6, 2014 04:49 PM
svenska
Sep 22, 2010 10:50 AM
Bobec
Nov 28, 2009 05:26 PM
curtisckey
Jan 22, 2008 06:24 PM
