Oil Cooler Hose Leak?
Old Jan 21, 2008 | 04:43 PM
curtisckey's Avatar
Default Oil Cooler Hose Leak?
Greetings Everyone,
I have a small oil leak at the fitting just below the upper radiator hose. I've circled it on the picture, and I think it is a oil cooler line. Is it possible that it just needs tightening? If so, how would you go about it. One other question, I just had the head gasket replaced, is this a fitting that the shop would have disconnected during the replacement of the head gasket? The reason I ask is that if I knew that it had been recently removed, then that might lean me more towards it needing tightening rather than replacement. Thanks as always for you guys help!
[IMG]local://upfiles/8412/EFF2363E7C8C431888A3B2E72DF9D8F3.jpg[/IMG]
Old Jan 21, 2008 | 04:55 PM
Default RE: Oil Cooler Hose Leak?
Sorry no pic there.
But the oil cooler lines have metal clips that hold them in.
Maybe a seal is going bad.
If you could get the pic to post I would be able to tell you better.
If you can't get the pic to post let me know I will give you my e-mail address and I will post it for you.
Old Jan 21, 2008 | 06:48 PM
curtisckey's Avatar
Default RE: Now The Pic Is There!!
Thought the pic uploaded, but it was 20 kb too big. Resized and reposted.
Old Jan 21, 2008 | 07:12 PM
The line lookes clipped in all the way maybe one of the 3 seals are bad.
Old Jan 22, 2008 | 06:54 AM
curtisckey's Avatar
Default RE: More Questions...
Thanks, Tech for having a look. This information, as information often does, leads to more questions... Are the seals replaceable, or must I replace the entire hose? Does it take a special tool to remove the clip? It appears that the clip is the thing holding the fitting together, is that right? Is this a job that an average "at home" mechanic can do, or is this one for the Vovlo shop?
Old Jan 22, 2008 | 06:24 PM
They can be replaced.
There is 2 o-rings and one clear thicker seal.
I use a pair of snap ring pliers that open when you compress the handles.That will open the clip and allow you to remove the line.
It should be like a 10 to 15 minute job.
Big_White
Nov 25, 2014 09:58 PM
kazbah
Aug 6, 2014 04:49 PM
svenska
Sep 22, 2010 10:50 AM
kevink
Jun 4, 2010 04:07 PM
illfrom
Mar 7, 2010 09:15 AM
