Oxygen sensor warning
Old Nov 24, 2007 | 04:42 PM
jaymac's Avatar
Default Oxygen sensor warning
On my 99 V70 awd on Thursday th electronic management light came on about an hour or so after ploughing through some heavy water.There was no change in performance and over the 90 miles back home felt nothing untoward .Took it to my non franchised Volvo dealer and the scan came up with front O2 sensor . the Light was reset and as it means a £300 Job chose to wait and see . So far now Sunday and lamp has not come back on and car is ok . Could this just be a glitch or is it likely to return I seem to recall in the past something about X number of cold starts after a reset. Any advice or information welcome
Thank you
Old Nov 26, 2007 | 12:47 PM
Default RE: Oxygen sensor warning
If it comes back again I would replace it.
Old Nov 26, 2007 | 12:52 PM
jaymac's Avatar
Thanks I would but just wondered if this was prone to blips
Old Nov 26, 2007 | 01:08 PM
It might be an Intermitant heater element problem.
It is only going to get worse.
Pretty common.
But usually when the code comes up it needs one.
Also make sure there is no vaccum leaks.
Old Nov 26, 2007 | 01:33 PM
jaymac's Avatar
Ok thanks for the info will watch it
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
Enzo cat
Feb 25, 2011 03:00 PM
netflash
Jan 31, 2005 07:56 PM
