She's a gusher!
Old Dec 14, 2010 | 06:15 PM
bitter356's Avatar
Unhappy She's a gusher!
Hello, 99 V70XC w/165k. Oil leaking various places, replaced flame trap system and oil cap gasket. Oil only comes out from under the oil cap after repair. About 1-2 oz per day. Any ideas? Thanks
Old Dec 18, 2010 | 08:42 AM
Does the oil cap fit snugly?
Old Dec 18, 2010 | 07:16 PM
bitter356's Avatar
Yes the oil cap fits quite well. the two tabs on the cap are in fine condition.
Old Jan 12, 2011 | 01:34 PM
Barnacle Bill's Avatar
Does the cap when loosened jump up and down while the engine is running? If so you still have a build up of internal pressure. And if the cap is well fitted, it will still leak. There is a hose from the top of the head to the flame trap, is it open and not clogged? My guess from experience is that it's not venting to the turbo. The hose from the trap to the turbo, how is it? Where the hose mounts to the "snout" that fits to the turbo? carbon can build up all along this route.
Old Jan 12, 2011 | 06:40 PM
bitter356's Avatar
Thanks for your response. I like the jumping cap method. Purchased a flame trap kit from IPD and believe that hose is included. I will double check this weekend. I am leaning towards an internal build up. Upon removing the flametrap, the block was plugged at the trap.Any ideas of cleaning outside of hot tanking the engine after dismantle?
Old Oct 31, 2015 | 06:19 PM
Czakky's Avatar
I second that pierce! Read your post a little too late and my aftermarket gaskets are leaking under static pressure... Oh well live and learn!
Old Nov 3, 2015 | 12:09 PM
Some people suggest Seafoam oil treatments to loosen crud before doing the flame trap, then you need to get in there with some tools to mechanically clean out the ports to the block as best you can. Don't do the Seafoam after doing the trap as you may loosen some sludge and push into the new trap.
turbo matt
Apr 3, 2011 07:19 PM
Pluis
Apr 27, 2010 12:55 PM
m1964
Sep 22, 2009 10:18 AM
dpvovo
Feb 1, 2008 10:49 PM
bunjamins
Aug 27, 2006 03:22 PM
