sluggish 2006 xc70
Old Sep 20, 2010 | 08:45 PM
bruinzca's Avatar
Default sluggish 2006 xc70
Bought a 2006 xc70 a year ago at 66,000 km now at 100,000 km and noticing some sluggish performance. Tried injector and fuel system cleaners and a new air filter. Helped a bit but something is missing from the performance when new.
Any suggestions?
Regards,
Bill
Old Sep 24, 2010 | 10:44 PM
91shelby's Avatar
throwing any codes? is it a turbo? tune up? plugs wires?
Old Sep 26, 2010 | 09:04 PM
bruinzca's Avatar
Thanks for the response.
Not throwing any codes and it is a turbo.
I have not yet replaced the plugs or wires. Do you think it might be a plugged fuel filter?
Regards,
Old Sep 27, 2010 | 12:33 AM
91shelby's Avatar
i would definitely check your plugs, fuel filter is possible, when is it sluggish? in boost or all the time? personally i dont think itd be your fuel filter. but wires and plugs would be a good possibility i would check plugs first since they are the cheapest to replace, also what kind of fuel do you run in it? have you tried doing the seafoam clean
Old Sep 27, 2010 | 09:18 PM
bruinzca's Avatar
91 Shelby,
Sluggish mostly in boost. It's when I notice it the most. I run regular fuel and I don't know what seafoam clean is.
I have run fuel system cleaner and injector cleaner a few times. Just the STP stuff in mixed in a tank of gas.
Thanks again for the help.
Regards,
Old Sep 27, 2010 | 10:01 PM
91shelby's Avatar
seafoam is a cleaner you can run thru your intake to help clean out the cylinders and valves, how long have you been running regular? i would really check your plugs, specially if its in boost. i believe they recommend premium i dont put anything below midgrade in my 95 turbo wagon
Old Sep 28, 2010 | 06:38 AM
bruinzca's Avatar
Reading other threads, I think you're right about the plugs. One last question. Which plugs? OEM from the dealer or another kind?
Old Sep 28, 2010 | 09:03 AM
91shelby's Avatar
Arrow
You can't go wrong with oem plugs though I personally run the iridium plugs
McBain
Oct 22, 2007 10:46 AM
740_in_TX
May 25, 2006 08:54 PM
Mecheng
Feb 24, 2006 12:25 AM
stever
Nov 29, 2004 10:57 PM
flyingbrick
Aug 26, 2004 05:53 PM
