94 940T sluggish,loses pwr
Old Nov 29, 2004 | 10:34 PM
stever's Avatar
Default 94 940T sluggish,loses pwr
howdy, new member and would appreciate any advice/help regarding my 1994 940 turbo automatic. replaced fuel filter, but still has occasional sluggishness, loses power, code came up 121, air mass meter replaced 40,000 miles ago. Time for another?? Also, stick shift won't get out of park unless i press the shift-over-ride button, ?related to Brakes? Will welcome any and all replies, thanks, Steve
Old Nov 29, 2004 | 10:57 PM
Default RE: 94 940T sluggish,loses pwr
Have you replaced the plugs,wires,dist cap,rotor?Also check for air leaks with the car running spray some carb cleaner around the intake and all vaccum lines.If the idle changes you found your air leaks.For the shift lock There should be a micro switch under the shifter plate that will need to be replaced.
louiebay
May 18, 2013 10:51 AM
shwebo
Jan 30, 2012 08:53 PM
jeffhestand
Nov 11, 2011 07:08 AM
jbkoonse
Jun 24, 2010 08:46 PM
rogue606
Feb 13, 2010 03:42 PM
