Stumped....abs/tracs lights
I was all set to send off my abs module to have rebuilt on my 98 V70XC that I just recently purchased, due to the abs/tracs light coming on and staying on.....when I noticed something very peculiar. I have checked it repeatedly the last few days and keep coming up with the same thing....here it is:
If I start the car (while it is in Park) withOUT putting my foot on the brake pedal....the abs/tracs light comes on and goes right off (as they should). However........if I put my foot ON the brake pedal and start the car....the lights stay on. We have had inclement weather recently and I could tell that the system is working correctly...SOOOOO.........
Is this still a condition that requires having the module rebuilt, or is there a different problem I need to check into???
Hmmmm...OK! By the way...the ONLY code that throws is the "P0108" code. I have spoke with you about it before, and you mentioned that I probably need to replace the barometric pressure sensor......trying to find one at a salvage yard now. Could the two problems somehow be related, in your opinion??
