viscous coupling noise
Old Feb 23, 2007 | 11:24 PM
mrscullini's Avatar
Default viscous coupling noise
'00 v70xc se with 93k miles
i have had the recent occasion to break the tires loose. i seem to be getting a "ratcheting" noise while the tires are slipping. once i gain traction, the noise is gone. the awd seems to be fine as i have confirmed power is transferred from the front to rear. does the vc make a noise while engaging? i would tend to think it is the vc over the bevel gear. i did a search without much luck. any thoughts, ideas, input, etc?
Old Feb 24, 2007 | 12:41 PM
Default RE: viscous coupling noise
Does your car have traction control?
If so I bet that is the noise you heard.
Old Feb 24, 2007 | 01:32 PM
mrscullini's Avatar
i do.
thanks for input.
Old Feb 24, 2007 | 01:41 PM
Did the gas pedal seem to fight you when you heard the noise?
Old Feb 24, 2007 | 02:58 PM
mrscullini's Avatar
ORIGINAL: tech
i'm not sure. i will have to check it again. shouldn't be a problem as the driveway is an ice rink right now. i will report back.
thanks.
BILL_MCCASSEY
Oct 1, 2023 02:52 PM
danielak0328
Aug 12, 2012 08:47 AM
rllittl1966@yahoo.com
Dec 4, 2011 01:24 PM
2008_XC90_AWD
Aug 18, 2008 10:14 AM
2008_XC90_AWD
Jul 26, 2008 09:36 PM
