volvo xc70 2000 stalling in gear
Old May 26, 2022 | 05:07 PM
madeesawnv's Avatar
Default volvo xc70 2000 stalling in gear
hi, i have read countless posts that sound similar to my problem, but none are exactly what i am experiencing.
My Volvo xc70 2000 SE starts, idles, and revs normally. when i try to put it in drive or reverse, it will stall immediately. i am able to restart the car, but never able to put into gear without stalling.
the last day i drove it (which was also the first time i ever experienced an issue) it stalled at a red light, and i was able to shift into drive by revviing engine while simultaneously shifting into gear. (i had to repeat this process every time i came to a stop.)
the revving is no longer an effective workaround for the stalling issue.
that night, looking under the hood, i discovered my fresh air intake had become detatched from the turbo inlet, and that was promptly replaced. but the stalling persists.
i have since replaced the MAF sensor, and just put in a brand new throttle body from Xemodex.. as well as removed and inspected vaccuum lines for leaks
any input would be very much appreciated..
the car has 165k miles on it, and has had virtually no issues since ive owned it.
Old May 26, 2022 | 05:36 PM
A good first step would be to scan for codes (in all the control units) and check the fuel pressure with a mechanical gauge.
91Volvo240survivor
Feb 7, 2022 08:18 AM
Vaswamp
Jul 24, 2021 02:08 PM
BigRed850
Jul 19, 2018 08:05 PM
