Volvo XC70 2009 Engine/Transmission trouble
Old Mar 4, 2020 | 12:19 AM
Spencer Hardy's Avatar
Unhappy Volvo XC70 2009 Engine/Transmission trouble
Hello there. I am having engine/transmission problems with my Volvo XC70. Earlier today I got in my car to start it and at the same time I started the ignition I simultaneously changed gears from park to reverse. Essentially, I started my car in reverse instead of park. This led to a sort of clicking noise and a "check engine light'" on the dash. The car won't turn over and every time I start the ignition I get the clicking noise and the light. The clicking noise sounds similar to the sound a dead battery but is more "clunky". I am able to shift gears but unable to start the car. I have attached a video to this thread which shows the engine and the clicking noise which is emitting from it.
File Type: mov
Old Mar 4, 2020 | 08:42 AM
You need to scan for the CEL to find the fault code. Did you try a jump start to see if anything changes (and to rule out a weak battery/cable issue). The shifter has a position sensor (google "Volvo PNP switch") that tells the ECU where the shifter is - normally when functioning properly you'd only be able to engage the starter with the shifter in Park so something is either broken or needs adjusting in the PNP. Next time it fails to start, try doing a "shifter row" (move the shifter from park to lo to park 10-20 times fast). then try starting again. This can clean off the contacts in the PNP enough get it to behave, but if not, you'd need to replace.
hman
Jul 24, 2016 07:27 PM
Nexed
2001-2013 model year XC70
Nov 16, 2012 10:45 PM
treumb
Apr 22, 2008 09:05 PM
brainymas
Mar 24, 2008 09:32 PM
woodsvolvo
May 25, 2007 08:14 AM
