What Timing belt kits I should choose?
Old Nov 13, 2007 | 07:11 AM
plopband's Avatar
Default What Timing belt kits I should choose?
I got 01 v70 xc,Turbo 2.5. Does anybody have experience to replace the timing belt? What is the correct part numbers for the belt, tensioner and idle pulley? How can I find those part numbers for my car.
I just found a timing belt kits from Ebay, including timing belt (274338), mechenical tensioner (30638277) and idle pulley (9146376). Are those correct for my car? How can know my car is with mechenical or other type of tensioner?
Many thanks,
Plopband
Old Nov 13, 2007 | 08:38 AM
Psaboic's Avatar
Default RE: What Timing belt kits I should choose?
The best place to check part numbersI ahve found is either at the dealer, or at some of the better on-line parts dealers. I tend to stay away from E-bay unless the person selling the parts is actually a Volvo parts vendor using e-bay as a way to increase sales.
Anyway, first off. if you car is a 2001 (as mine is) you should have the mechanical tensioner. I replaced my own timing belt and it is not that difficult.
Secondly, check these vendors: fcpgroton.com, egerman.com ipdusa.com, and autohausaz.com for part numbers and prices.
Good luck
Old Nov 13, 2007 | 09:15 AM
plopband's Avatar
Thanks Psaboic. Do I have to have the special tool (counterhold 9995433)? What did you use to dismount the idler pulley?
Old Nov 13, 2007 | 05:45 PM
You don't need any special tools to do it.
Are you talkling about the serpentine belt idler?
Old Nov 14, 2007 | 07:09 AM
plopband's Avatar
I mean the timing belt idler. This will be my first attempt to change the timing belt. But I never look at the timing belt assembly. Some XC timing belt replacing instructions mention about the counterhold tool needed to get the timing belt idler off. I do not know if I can finish the work without this tool.
Old Nov 14, 2007 | 08:40 AM
Psaboic's Avatar
I didn't need to use a counterhold.
Glenn
Old Nov 14, 2007 | 09:00 AM
plopband's Avatar
OK! Now I am confident with timing belt DIY. Thank you so much.
Plopband
Old Nov 17, 2007 | 06:11 AM
mncx's Avatar
note: keep in mind 01 turbo exhaust side have return spring on the exhaust cam gear (will jump back). have to lined up all 3 timing marks.
light8008
Apr 15, 2012 10:54 PM
haydenm315
Jun 30, 2008 10:25 PM
annalulu
May 12, 2007 11:43 AM
cgabb1
Sep 17, 2004 03:09 PM
cgabb1
Aug 5, 2004 12:25 AM
