engine oil cooler
Old Nov 12, 2007 | 07:17 PM
98xc70nny's Avatar
Default engine oil cooler
looks like i have a leaky engine oil cooler hose. i understand there are 2 pieces of hose and some o rings. are these easy to get to and replace? have a great day.
Old Nov 12, 2007 | 09:10 PM
Default RE: engine oil cooler
They are kind of a pain but take your time and you will get it.
Old Nov 15, 2007 | 09:51 AM
98xc70nny's Avatar
hi tech,
if i am not mistaken the leak appears to be coming from a center piece on the engine oil cooler line. not metal. is this something i could get at any parts store. has metal clips at both ends? is this some special volvo size. Have a great day.
-marsh
Old Nov 15, 2007 | 08:11 PM
Can you post a pic of where you think it is leaking?
Old Nov 17, 2007 | 06:20 AM
mncx's Avatar
if u can remove the oil cooler and cleaned the corrosion off the holes where the o-rings and the pipe fits into would give u better seal when new o-rings and pipe are being installed. if not cleaned it may leak on u... hope that help
draco35
Jan 12, 2024 10:27 AM
ahilfman
Aug 19, 2010 10:31 PM
illfrom
Mar 7, 2010 09:15 AM
sp5368
Mar 24, 2006 02:11 AM
