Wheel hub loose after axle replacement
Old Oct 22, 2007 | 08:40 PM
mafiosoroso's Avatar
Default Wheel hub loose after axle replacement
I just had the lower control arm and the axle replaced on the passenger side of my 1998 V70 CX.
After driving about 70 miles I started hearing a vibrating noise in the front passenger side, which goes away when I'm turning or making a curve.
Lifted the car up and there is play in the wheel -- it moves with the hub. I looked underneath, and the axle is staying stationary as the wheel hub moves.
I am wondering if the the person who fixed it (at a regional chain) messed something up... I couldn't unscrew one of the lug nuts (I bent the tool!!!) on my aluminum wheels.
Any thoughts?
Old Oct 22, 2007 | 09:20 PM
Default RE: Wheel hub loose after axle replacement
Sounds like the axle nut wasn't torqued properly.
I have seen that many times.
bobinyelm
Nov 16, 2017 09:37 PM
puxnstx
Dec 13, 2014 11:36 AM
EMD886
Oct 19, 2012 10:13 PM
madymo3d
Aug 14, 2012 11:35 AM
jabbo
Jan 24, 2009 05:13 PM
