Axle stuck in hub
Old Jan 23, 2009 | 03:25 PM
jabbo's Avatar
Default Axle stuck in hub
Hello folks.
I'm replacing the left axle on a 2001 S40. I've whacked it pretty hard using a drift with a hammer, but it's not budging. VADIS gives me the following: "Hint: if the drive shaft sticks in the hub, tap it with a copper or a rubber mallet."
I've done a lot more than tap it. Any suggestions?
Old Jan 23, 2009 | 05:17 PM
Default RE: Axle stuck in hub
I use a tool that goes onto the lugs and snugs up then the center screw pushes the axle out.
Old Jan 23, 2009 | 05:22 PM
jabbo's Avatar
Thanks for the suggestion. I'll try that, but I'm suspicious that it's gonna take more than that - I've whacked it pretty hard.
Old Jan 23, 2009 | 05:27 PM
I know the feeling had them like that but the tool usually gets it.
Old Jan 24, 2009 | 03:14 PM
jabbo's Avatar
Ok...so I've got the tool on the hub...I've been cranking on the bolt...axle hasn't moved. All I'm doing at this point is grinding metal off of the end of the screw and the end of the axle. Am I going to have to remove the hub with axle attached and take it to a machine shop?
Old Jan 24, 2009 | 04:38 PM
Hopefully the tool is pretty beefy. Get it PRETTY tight then tap the center screw with a hammer and tighten it more and hit it again. Keep working it and it should come loose.
I have a really heavy duty tool and I can hit mine really hard.
Old Jan 24, 2009 | 05:13 PM
jabbo's Avatar
It broke free!!! Hopefully I can finish up tomorrow.
Thanks a lot!!!
bobinyelm
Nov 16, 2017 09:37 PM
puxnstx
Dec 13, 2014 11:36 AM
EMD886
Oct 19, 2012 10:13 PM
madymo3d
Aug 14, 2012 11:35 AM
mafiosoroso
Oct 22, 2007 09:20 PM
