Will a b5244t3 (01+) swap in place of a b5244t (00)?
Old Oct 25, 2010 | 11:56 AM
Heath7's Avatar
Default Will a b5244t3 (01+) swap in place of a b5244t (00)?
It seems the b5244t3's are more readily available (and cheaper) than the b5244t's. Would the b5244t3 from an 01+ work in a 00 v70 xc or are there variances that would cause issues?
My car has a snapped timing belt and hopefully later today I will know the extent of damage. I may just swap a low mileage head on to the current block (190k+) but if there is piston damage a motor swap seems more economical.
Any and all info is appreciate fellas!
Old Oct 26, 2010 | 08:18 PM
It might you just need to make sure the new motor is not dual VVT.
Old Oct 27, 2010 | 10:32 AM
Heath7's Avatar
Understood. The pistons had numerous indentations caused by the valves but nothing detrimental as far as I can tell. I used a polishing wheel on a right angle die grinder and took the sharp edges off. I then followed up with a wet sand (400 grit and wd-40).
The pistons cleaned up nicely. I don't expect any hot spots leading to preignition.
I plan on picking up a used head and going that route. Wish me luck
Old Oct 27, 2010 | 06:45 PM
Good luck you should be fine!
Kubes
1998-2000 model year V70
Nov 6, 2013 08:10 AM
AaronD81
Dec 20, 2006 12:28 AM
chrismears
Dec 11, 2005 11:35 AM
tomservo
Sep 29, 2005 04:47 PM
Bill C
Nov 23, 2003 03:37 AM
