engine miss and smoke sometimes at idle
Old Jan 30, 2011 | 06:19 PM
mesa's Avatar
Default engine miss and smoke sometimes at idle
Hi , new here to forum. I have a 2005 volvo xc 70 with about 123000 miles. Installed new PCV after having blue smoke at idle. Still Have some smoke at idle, a small puff here and there but much improved after the pcv change- not blue anymore -
Just after I changed the pcv, I noticed a slight miss or stutter on speeds above 45 . Again , wasn't everyday . THis weekend, noticed miss about 5 times on a longer highway drive , when attempting to change lanes etc.
I have changed the spark plugs, cleaned MAF sensor. NO CEL.
I checked all hoses, etc today and got down to the turbo. Noticed some some shaft play as when I pushed the vein it would tap against the housing. I don't have any experience with Turbos.
Could the smoke on idle and now the miss be caused by a bad turbo or are there other things I should be looking at? Also, know any good places to get a used Turbocharger for a 2005 volvo xc 70 ?
Old Jan 30, 2011 | 08:09 PM
If the fins are hitting then the turbo is worn out.
Old Jan 30, 2011 | 10:16 PM
mesa's Avatar
can the bad turbo also cause the miss at highway acceleration?
Old Feb 5, 2011 | 08:21 PM
Maybe if it is dumping a bunch of oil into the system.
Old Dec 14, 2012 | 09:21 AM
cloud's Avatar
Banned
There are two different reasons for black and white smoke coming from the tail pipe.
Black smoke means fuel runs rich (car getting to much gas). Check fuel pressure/air filter.
In some cases the white smoke means car is burning oil or transmitting fluid. Have them checked/replaced.
If you can feel a smelly smoke it can be catalytic converter.
In a worst scenario if car blowing white smoke it can be engine coolant is getting into an engine cylinder from a bad head gasket ,or a warped/cracked head. So you need to keep your eye on coolant level and check your engine for overheat.
87roadwarrior
Aug 26, 2015 10:26 PM
hunterw0026
Mar 21, 2011 09:49 AM
850R Dave
Dec 16, 2009 09:41 AM
MN55082
Jul 1, 2008 08:25 PM
phils94850
Mar 18, 2007 11:25 AM
