05 XC90 2.5T P0343 Code
Old May 1, 2017 | 07:46 PM
FREE-PPV's Avatar
Default 05 XC90 2.5T P0343 Code
OK, I kept getting this code, says to replace cam crank sensor, so bought new one, same problem, consistent, I reset code, can drive distance, no engine light, runs fine, but when I shut off and next time I start, engine light is on again and same PO343 code is back. Anything else anyone know which can cause this code?
Thanks,
Old May 2, 2017 | 08:50 PM
Volvotechreally's Avatar
Thanks,
Possible starter. Does it ever crank oddly when you are starting it. A starter with excessive wear can cause a false signal in the RPM sensor circuit as the wires route very close to the starter. I am unfamiliar with PO codes but the volvo code is a ECM-5200.
Old Jun 2, 2017 | 07:34 PM
FREE-PPV's Avatar
Thanks, but seems to start fine, no strange sounds. Mystery for sure and I can't get inspection updated while check engine light is on.
Mark-V
Feb 19, 2017 12:06 PM
Elsid
Sep 9, 2010 08:42 AM
badmonkey
Jul 28, 2008 09:15 PM
d2jreality
Jan 5, 2008 06:29 PM
gzh
Mar 21, 2007 09:29 PM
