2004 XC-90 T-6 - Sway bar links??
Hello,
I am experiencing a rattle sound from the front end when I go over bumps at low speed. I had the ball joints replaced by a mechanic who I've recently left for another mechanic because he failed to fix the problem because I still have the same rattle. After inspection by another mechanic, I'm being told that its probably the sway bar links. I don't think its the spring seats, which I believe sit on top of the struts? Someone else told me it could also be the sway bar bushings. Has anyone ever experienced this problem?
Thank you.
Thank you.
