2004 XC90 Connection
Old Dec 5, 2015 | 07:04 AM
mkquehl's Avatar
Default 2004 XC90 Connection
Where do I connect to the vehicles communication port. Got the check engine dummy light on. but shes running fine?
Old Dec 5, 2015 | 08:02 AM
pkrface's Avatar
Should be a little access panel below the steering column. Google an image of an OBDII port if you don't know what it looks like. Also, you can take the car to any AutoZone, Advance Auto Parts, etc. and they should be able to read basic codes for you for free in the hopes you will buy the part from them.
Old Dec 5, 2015 | 08:19 AM
mkquehl's Avatar
Found it. Was able to communicate with the vehicle but there were no codes to read?? The dummy light is still on but no codes? What did I do wrong? lol went through the whole menu from start to finish with the code reading unit at Advance Auto? Nothing. Whe I start up the vehicle it does state in the message area bottom left of dash that the security system needs service? Then it clears
Old Dec 5, 2015 | 09:36 AM
ES6T's Avatar
A cheap scanner won't be able to check alarm codes. But if the check engine light is on, it should be able to read those.
foral
Sep 23, 2006 01:15 AM
benjess
May 12, 2006 07:38 AM
daveawd
Nov 26, 2005 09:29 AM
jcueto
Oct 4, 2005 08:03 PM
pitar
Jul 29, 2005 03:26 PM
