2006 xc90 3rd row seatbelt replacement
Old Dec 15, 2016 | 06:41 PM
green2man0's Avatar
Default 2006 xc90 3rd row seatbelt replacement
I recently bought a 2006 xc90 4.4 awd...it needs the driver side seatbelt replaced. I ordered a used one and just received it. The seatbelt is locked into the retracted position. I can't pull the belt out from the spool...browsing the forums I found a few posts that state the seatbelt is a non servicable part and if it gets stuck it's no good. Is this true or does the little 2 pin connector (electronic) release the seatbelt. Info would be helpful before I start taking stuff apart. Thanks
Old Dec 15, 2016 | 09:37 PM
green2man0's Avatar
Nevermind, the seatbelt orientation is very sensitive. If held in a perfectly vertical position the locking mechanism releases.
Captpetek
Jul 7, 2019 03:58 PM
H1PSI
Jan 28, 2017 10:54 PM
onsight512
Nov 10, 2010 02:11 PM
Rocky416
Oct 29, 2010 01:42 PM
jnduke
Oct 8, 2010 09:17 PM
