2006 XC90 throttle pedal position sensor
Old May 5, 2020 | 02:01 PM
Shawnd's Avatar
Default 2006 XC90 throttle pedal position sensor
I recently had issues with choppy idle and shut down, if you could get it to move the car full go about 20mph with the pedal pressed all the way. I got a code for the TPS (throttle position sensor), I replaced the pedal with sensor and it corrected the issue for about a day then back to the same issue. My question is when I replaced the pedal/sensor was there a procedure I was supposed to follow before, during or after the replacement because I just simply removed the old and installed the new
Shawnd
May 1, 2020 03:33 PM
jamesrshelby
Apr 9, 2019 02:06 PM
mojorysn
Feb 12, 2014 11:02 PM
ANDY BARNES
Oct 7, 2011 01:11 PM
SarahScallop
May 17, 2010 05:18 PM
