New throttle pedal position sensor 2006 XC90 2.5 2wd
Old May 1, 2020 | 03:33 PM
Shawnd's Avatar
Default New throttle pedal position sensor 2006 XC90 2.5 2wd
I recently had trouble with the “P102” code (I think was the code), for the throttle position sensor. Was having issues with a very rough idle fluctuation then shut off. Read the code and replaced the throttle pedal position sensor. That seemed to do the trick for about a day then it started with the same thing again. My question is, was there some sort of procedure I needed to follow before, after or during the swap that I should’ve done? because I just simply swapped the pedal/sensor out.
jamesrshelby
Apr 9, 2019 02:06 PM
ANDY BARNES
Oct 7, 2011 01:11 PM
victoruk2
Feb 12, 2011 05:34 PM
dahubb
Jan 20, 2010 07:44 PM
knight rider
Oct 10, 2008 07:41 AM
