2011 XC90 3.2L A/C only blows cold when rear a/c button is pressed on.
Old May 25, 2024 | 02:34 PM
KatrinaO's Avatar
Default 2011 XC90 3.2L A/C only blows cold when rear a/c button is pressed on.
UPDATE: Replaced the pressure control valve and ac is working great. I ordered my part from FCP Euro.
Volvo AC Compressor Control Valve - Genuine Volvo 31305844
When idling, it’s cool but not cold (with rear ac on). It’s already in the 90’s here 🥵
Do you think the compressor needs replaced? Maybe just the pressure control valve? Something else? Thank you!
Old May 26, 2024 | 07:22 AM
It's actuality a displacement control valve - and that's certainly a common failure that can cause poor cooling at lower speeds. .
Old May 26, 2024 | 08:02 AM
KatrinaO's Avatar
Thank you, I’ll see if FCP has the part.
Old May 26, 2024 | 05:33 PM
You might want to actually diagnose (or have someone diagnose) the problem first - it's pretty frustrating to replace something (that can cost a few hundred dollars) and have it not solve your problem.
Old May 26, 2024 | 10:21 PM
Niklas11Braun's Avatar
Besides the compressor or pressure control valve, it could also be a problem with the system's airflow or temperature regulation.
First, check the refrigerant levels and make sure there are no leaks.
Also, check the A/C condenser and radiator for any dirt or things blocking airflow.
A clogged or dirty cabin air filter can also reduce airflow and affect A/C performance.
Plus, check the A/C condenser fans and compressor clutch.
Cookster
Oct 29, 2022 04:52 PM
Volvo2011
Aug 3, 2022 03:12 PM
raker10s
Aug 20, 2021 03:51 PM
lnguyen_21
Mar 9, 2012 12:45 PM
littlekings
Jun 29, 2010 02:02 PM
