2016 T-6 Momentum - Won't crank
Old Oct 31, 2023 | 01:26 PM
Playmaker's Avatar
Default 2016 T-6 Momentum - Won't crank
Hi,
My son's 2016 XC 90 T-6 started acting up yesterday as follows; started the car after sitting idle (3 hrs) got to first stop light and the auto stop invoked and then the car wouldn't start. After a few times of trying, it finally started and he drove it home and parked it. When out to start it this morning, no response, not turning over and all you hear under the hood is what sounds like electronic switches going on but it will not turn over.
FYI - the main battery is fully charged and the auxiliary battery was replaced about 8-10 months ago. .
There were no error messages whatsoever when it stopped at the light or on the drive home thereafter. There are no messages now, it is just a dead player.
Any feedback would be appreciated.
Old Nov 10, 2023 | 12:36 PM
Playmaker's Avatar
Update - we solved the problem. It was a loose positive connection on the starter. Tighten it up and it has been fine since.
Old Nov 10, 2023 | 01:07 PM
Bob r's Avatar
Thank you for the update.
Old Mar 14, 2024 | 11:41 AM
jacob828's Avatar
I know I am a little late to this thread. Your issues sound very similar to what I am having in my 2020 xc90. Do you have any resources I could use to check connection on my starter? I am trying to find a video or guide to do so. Thank you!
Old Mar 15, 2024 | 05:48 PM
Playmaker's Avatar
Hi Jacob,
Find the location of the starter, locate the positive cable coming to the starter, it should be red in color and there is a black plastic cover over the connection. If it's like the 2016 it will not be easy to get to.
First try and tap the connection with a screwdriver or something you can get down to it. Tap it or try and move it a little and see if it starts. If it does, you are going to have to get to the starter connection and tighten it.
If that doesn't affect it, then try and pop the cover off and take a open end wrench (I believe its 12 mm) and see if its loose, if so try to tighten it holding the connection cable so you don't move the metal housing on the starter connection.The little base plate of the connection on the starter could move enough to hit up against something else and ground out. Once you have accomplished that try to start it. If it starts obviously it was loose.
I want to let you know, eventually we ended up changing the starter out and it's run fine every since.
Sharkie
Jul 14, 2022 02:38 PM
NA Sharp
Nov 24, 2020 08:34 AM
viking2020
Aug 22, 2019 03:23 PM
brownbrad
Jul 16, 2016 03:06 AM
