2016 Volvo XC90 leaking vacuum pump
Old Apr 6, 2025 | 08:10 PM
Jdean82's Avatar
Default 2016 Volvo XC90 leaking vacuum pump
Hello, I have a 2016 XC90 T6 Momentum. The Volvo dealer informed me that the brake vacuum pump is leaking and needs to be replaced. I found an aftermarket seal kit for it and would like to try and replace the seals first before having the part replaced. I’ve located the brake vacuum pump, however there is a part of the intake tubing that is blocking me from getting to one of the bolts that holds the pump on the engine and I can’t figure out how to remove it. I have attached pictures for reference. I would like to remove as little as I can. Thank you in advance for your help.
Sharkie
Jul 14, 2022 02:38 PM
dombogo
Jun 23, 2021 01:19 PM
shepcontracting
Oct 5, 2018 11:36 AM
wespetersen@gmail.com
Jun 10, 2016 09:15 AM
Sensation!
Oct 13, 2015 08:21 PM
