2016 XC90 Daytime Running Light Issue
Old Jul 25, 2018 | 11:39 PM
farmfly's Avatar
Question 2016 XC90 Daytime Running Light Issue
The passenger side daytime running light (DTR) quit working on our 2016 XC90. When the lights are first turned on, the outside of the DTR will turn on for a second and then go out. It looks like one of the LED's might be out. It's tough to tell where the LED's are located though. Are there two on the outside and one on the inside? Is the system smart enough to shut itself off when a LED light is out? I tried to take the headlight assembly out and it looks like you might need to remove the bumper cover to remove the assembly. Has anyone had issues with the running lights? How hard is it to replace them?
This is a video of when the unlock button is pressed. The light flashes orange and then the white appears for a second and goes out. It looks like it should have another light in the middle on the right side and possibly in the middle on the left.
File Type: mov
Old Jul 25, 2018 | 11:41 PM
is your car still under the factory warranty?
Old Jul 25, 2018 | 11:50 PM
farmfly's Avatar
No, the warranty is expired.
Old Jul 26, 2018 | 05:23 AM
ES6T's Avatar
I haven't run into this issue yet but I don't think there is anything you can do except replace the headlight assembly. I'll have to look into it when I have time at work.
Old Jul 26, 2018 | 08:14 AM
farmfly's Avatar
I'd really appreciate that. Thank you.
Old Jul 26, 2018 | 01:29 PM
ES6T's Avatar
Looks like there is a "controller" mounted to the back of the headlight that is available for replacement. I'd have to dig into the wiring diagrams later if I have time to see if this controls those.
Old Jul 26, 2018 | 10:44 PM
farmfly's Avatar
That would be great if you could look into the controller controls. I wonder if I could move the controller to the other side for troubleshooting...
Old Aug 3, 2018 | 01:18 PM
farmfly's Avatar
I took our XC90 to the dealer and they said the headlight needs to be replaced. I thought he said it was the module. I'm guessing he meant the controller on the back. They will replace the entire headlight. The good news is that I found out I am still under warranty.
Thanks for the help!
Old Jan 20, 2024 | 06:30 PM
avolvoproblem's Avatar
I know it's been a few years but ES6T did you ever find out if that controller is in charge of the thor's hammer DRL? I'm having a different issue than farmfly (my DRL works intermittently. Turn signal works 100% of the time though) so I think it's a faulty controller.
Timber
Feb 24, 2023 11:42 PM
Mattweaklend
Jul 5, 2017 09:26 PM
ct_purley
Nov 2, 2016 06:42 PM
wespetersen@gmail.com
Jun 10, 2016 09:15 AM
Sensation!
Oct 13, 2015 08:21 PM
