2016 xc90 engine overheat
I purchased a 2016 Volvo XC90 May of 2018. In November 2018 my engine light came on and it was time for annual maintenance. I brought my car in to the Volvo dealership and they did the usual maintenance and replaced a coolant tube that was recalled. After I got my Volvo back the engine light began to come on again. I brought my car back to the dealership and they declared nothing was wrong. Then I began to get an alert that my engine was over heating and to stop driving. I brought the car back to the shop and they declared the temperature gauge was broken. They replaced this but the overheating message still appeared when they would attempt to drive the car, at idle it ran fine. They communicated with Volvo Headquarters and after weeks declared the problem was the water pump. After removing the water pump they could see it was damaged. They then replaced it, however the engine light was still appearing. They did more tests and found a clogged tube, which they replaced. My car is now seemingly running fine. However, with Volvo’s reputation this did not seem like problems a 2 year old car should have. Weeks of being car-less and thousands of dollars later. Still love my Volvo XC90, hope this message helps someone.
you have a part number of the hose they changed so that I can have them have a look at it. That would be very helpful.
wespetersen@gmail.com
Jun 10, 2016 09:15 AM
Sensation!
Oct 13, 2015 08:21 PM
