2016 XC90 Frond end snapping sound
Old Jul 27, 2023 | 12:14 PM
Bob r's Avatar
Default 2016 XC90 Frond end snapping sound
I have a 2016 xc90 T6 inscription, Stating to have an issue with front suspension, snapping sound when turning wheel. Not all the time intermittent. Any Ideas?.
Old May 25, 2024 | 10:38 AM
kgalarza's Avatar
Bob,
Did you ever figure this out? I have a similar issue and it is only when I put the vehicle in reverse. It sounds like it is coming from my front left and I am leaning towards a failing/failed CV.
Old May 26, 2024 | 09:54 PM
Niklas11Braun's Avatar
Yep, those symptoms could mean the CV joints are wearing out. But check for other issues too, like worn bushings, loose tie rod ends, or bad ball joints.
Listen for snapping or popping noises during turns, which could also be from worn wheel bearings.
Plus, inspect the brakes for loose or worn-out pads, calipers, or rotors.
creinhard123
Aug 17, 2020 11:29 AM
viking2020
Aug 22, 2019 03:23 PM
shepcontracting
Oct 5, 2018 11:36 AM
Mattweaklend
Jul 5, 2017 09:26 PM
wespetersen@gmail.com
Jun 10, 2016 09:15 AM
