About to do timing belt- any advice?
I'm about to do the timing belt and idler pulley on my 03 T6. I've got a new water pump to put in too. I've got the VADIS instructions, I'm just wondering if you guys have any other words of wisdom to save me any time or aggravation. It sounds like I may need a T-stat nipple. I may get one before I start. Any help would be appreciated. Thanks
Thanks for that, luckily I had the T55.
Man this thing has been a PITA the whole time! I finally got the t-stat nipple off intact and moved all of the reservoirs and ecm box. Still wasn't enough room for TB cover.
Then after finally getting the cover off and removing the dampener on the crankshaft there wasn't enough room between the aux belt pulley and the lower motor mount to get the belt off.
Now, I got the water pump unbolted but there's not enough room to get the damn thing out. Everything is like my motor is a couple of extra inches to the pasenger side or something.
Have any of you guys had to remove the bottom crankshaft pulley to do this job? VADIS doesn't tell me to in the instructions that I have but if I remove it at least I think I can get my waqter pump out and new TB back in.
russellsv40
06-02-2011 12:02 PM
WolfPlayer
04-22-2011 09:39 PM
STREETFIGHTER50
10-23-2009 10:07 PM
KellyW.
05-31-2008 08:32 AM
jollygoodgold
07-16-2007 12:06 PM
