Anti Skid Service Required
Old Jul 15, 2019 | 07:58 AM
Paul Wood's Avatar
Default Anti Skid Service Required
My 2004 XC90 had the check engine light on with several codes related to the yaw speed rate sensor. The Anti Skid Service Required message was also displayed. I pulled the sensor out and found the connection to be corroded. I cleaned the pins and reconnected. The codes disappeared but the Anti Skid message is still displayed. Any suggestions on a way forward. There does not seem to be any problem driving the car.
Old Jul 15, 2019 | 03:50 PM
you need to see if you can find a fully featured OBD2 scanner or a shop with VIDA-DICE to view then clear the codes. If the codes return, then you know what else needs to be fixed. Not all ODB2 readers can do the chassis/ABS codes or the proprietary Volvo codes.
David Ward
Jan 13, 2022 03:34 PM
Rickswood
Mar 8, 2019 10:48 PM
justinmandrigues
Apr 20, 2014 01:22 PM
logisoft
Jan 29, 2010 08:56 AM
michael33
Sep 2, 2007 11:39 AM
