Anti skid service required
Old Sep 14, 2018 | 12:54 PM
David Ward's Avatar
Default Anti skid service required
Hi I have a Volvo s40 2010, lately it's coming up on the dash anti skid service required reduced engine performance. And the car is going into limp mode. I have to turn car off and switch on again.. Any suggestions
Old Sep 14, 2018 | 04:18 PM
moved your thread to the s40 board. Did you have the car scanned for any fault codes? It may be a wheel sensor or an issue with the ABS controller. Did you have any recent brake work etc?
Old Sep 14, 2018 | 04:49 PM
tony1963's Avatar
On S60 models, my experience is that the problem is related to the steering angle sensor. I agree with above - you can't do anything until you get codes.
Old Jan 13, 2022 | 10:48 AM
Stilyana's Avatar
Default S40 2010
Hello,
I have the same problem, but i have fault code P1264. Any ideas??
Old Jan 13, 2022 | 03:34 PM
Google is your friend: see P1264 Volvo Volvo DTC Code | EngineDTC.com
That code could be referring to a speed sensor signal which disagrees with a signal from the cruise control module. Given this is vehicle specific, your next step should be to have a dealer or volvo friendly shop do a deeper scan with a VIDA system to intepret the proprietary data correctly.
Paul Wood
Jul 15, 2019 03:50 PM
Seans
Mar 24, 2018 09:35 AM
Lex44
Apr 10, 2013 02:38 AM
s40clueless
Jan 24, 2012 01:49 PM
chrissygm
Sep 30, 2008 05:53 PM
