Anyone able to remove cracked side decal?
Old Apr 5, 2018 | 04:55 PM
GTvolvoxc90's Avatar
Default Anyone able to remove cracked side decal?
This side panel decal is cracking. Have any of you removed? And if so how did you do it?
Old Apr 6, 2018 | 12:07 AM
Welcome to VolvoForums GTvolvoxc90
I haven't done one but I would think using some gentle heat would work. Hair dryer or heat gun. That's how they remove factory trim that uses adhesive rather than clips.
Attached Thumbnails Anyone able to remove cracked side decal?-tumblr_mk2r0zcizh1r5wnj1o1_500.gif
Old Apr 6, 2018 | 06:59 AM
tony1963's Avatar
Any body shop can remove these with a heat gun for a few bucks. I would suggest replacing them as they aid in protecting the paint in that area.
Old Apr 9, 2018 | 08:54 AM
Tried using a hair dryer on high heat and didn’t do much. The decal is pretty dry and cracked.
Old Apr 9, 2018 | 04:17 PM
tony1963's Avatar
The only thing that the heat will do is melt the adhesive and allow the clear to come off. If the adhesive is that far gone and hard, then try 3M adhesive remover and a plastic tool to try and work it away from the paint.
This will be a slow process I assure you. Before I'd spend that much time, I'd see if a body shop would do it.
bcolins
2001-2013 model year V70
Feb 4, 2014 10:16 AM
123popeye123
May 1, 2013 06:54 AM
MattyXXL
Jan 8, 2012 04:24 AM
tobolate
Nov 26, 2009 11:10 AM
Lyonsroar
Nov 1, 2009 05:28 PM
