In a bad situation. No AWD
Old Oct 7, 2010 | 09:05 PM
upsidedown's Avatar
Default In a bad situation. No AWD
Hi All, I just purchased a 2004 xc90 2.5 from out of state. It has an engine leak which I beleive is the camshaft seal. So i'll have to search for that fix. But I do not have AWD. I did a lot of searching. I have a "anti skid service required" display on the dash. I put it up on the lift today to try and find out whats up. I can spin the driveshaft freely. It does not move anything. the rear tires also seam to move independent of each other. On a ussual rear dif. you spin one tire and the other one spins the opposite way. These just seam to spin alone. If I turn one rear tire I can feel a drag on the driveshaft like it wants to spin. So any one have any ideas. I am not sure what is suppose to spin and what is not. Thanks in advance.
Old Oct 9, 2010 | 09:37 AM
upsidedown's Avatar
Beuller.........Beuller........
Old Nov 4, 2010 | 09:16 AM
DPW-CT's Avatar
Default Similar issue
Please let me know what you find out - we have a similar issue 2004 xc90 T6
Old Nov 5, 2010 | 05:21 AM
gshadow325's Avatar
bevel gear collar would seem like the culprit.
look here and you will find out
http://www.volvoforums.org.uk/showthread.php?t=107241
Old Nov 5, 2010 | 07:31 PM
ES6T's Avatar
Information removed.
Old Dec 24, 2010 | 11:21 PM
upsidedown's Avatar
Well the splined collar was stripped out so I swapped that out and now the AWD works. The antiskid service is still on . Dealer states its from a contact ring in the steering wheel. Ill tackle that after I figure out the major oil leak from the front of the engine.
Ferox
Apr 20, 2015 05:47 PM
x-angel
Jun 8, 2012 12:08 AM
ricky
Aug 27, 2009 06:05 PM
polarbearonfire
Mar 22, 2009 09:11 PM
MikeySq
Oct 18, 2008 08:02 AM
