Battery Question
Old Oct 22, 2017 | 08:53 PM
green2man0's Avatar
Default Battery Question
I have a 2006 xc90 4.4L. I've noticed symptoms over the past few weeks of a weak battery. Today it failed to start so I went to the parts store to get a new battery...The guy asked me if I had the electrical upgrade? Wasn't sure but there were 2 options for batteries a normal sized 600 cca unit and a unit about 4inches longer rated at 950cca...I had the cover on so wasn't sure of what was in there. Had the smaller original vovlo unit. Got the bigger battery and it went right (there were 2 mounting holes of the battery hold down to fit either the small or large battery). I'm curious if the electrical upgrade refers only to the battery and nothing else...also was the larger battery a factory option? You'd think the the 4.4 would come with the bigger battery.
Old Oct 25, 2017 | 04:41 PM
Nichals's Avatar
Typically, the larger battery are for colder climates. There is not typically a paid upgrade you can get, its more where you live. The higher the CCA the better in my opinion. This will not last longer than the smaller one, but if you drive to the north, you wont have issues starting on the larger battery, but may have issues with the smaller battery.
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
greydiesel
Aug 16, 2009 05:18 PM
cmercon
Feb 2, 2009 02:15 AM
azalea
May 16, 2006 03:16 PM
