Check Engine Light - P0111 - Intake Air Temperature Sensor
Old Jul 17, 2014 | 03:47 AM
thegazelle's Avatar
Default Check Engine Light - P0111 - Intake Air Temperature Sensor
Hi there...so my check engine light has come in within the past few days with this code and I had it scanned yesterday...
P0111 - Intake Air Temperature Sensor - Circuit Range / Performance Problem
Anyone know what this is, what may cause this, and how easy (or costly) it is to fix? Thanks. I have an 04 XC90 2.5T with 228,000 KM on it.
Old Jul 17, 2014 | 09:00 PM
Joshinator99's Avatar
The intake air temp sensor varies it's resistance based on the temp it's seeing. If it shorts out or goes out of its normal range I will set a code. You can usually use a multimeter to check it.
Old Jun 27, 2019 | 08:24 PM
karma's Avatar
Default where is the IAT sensor located?
I have a 2004 xc90 2.5T. code says Faulty IAT. I ordered one online from euro whatever. It does not look like anything on my engine. Is there a diagram out there somewhere I can view? I can change it if I knew where it is . thanks for any help
Ricbassman
2001-2013 model year V70
Nov 19, 2020 09:14 AM
Montyhaul
Jun 11, 2017 09:46 AM
jdsmith
Jun 8, 2012 11:42 PM
Delirious
May 16, 2012 09:46 PM
aready
Aug 4, 2007 04:34 PM
