I can't find my intake air temperature sensor
Old May 9, 2017 | 09:34 PM
Montyhaul's Avatar
Default I can't find my intake air temperature sensor
2005 XC90 has a check engine light on and it won't pass the emissions test within on. My scanner says it has a bad intake air temperature sensor, it reads about 120 degrees higher than ambient temperature when engine is cold. Problem is I can't find it on my vehicle. I ordered a new one so I would know what it looked like but I still can't find it. Any help would be appreciated.
Old Jun 10, 2017 | 06:39 AM
Montyhaul's Avatar
Thumbs up Intake Air Temperature Sensor Location on a 2005 XC90 2.5T
Well just in case anyone else would need this information after a month of talking with eEuroparts.com who made me feel they were trying, searching the internet, calling local dealerships. I found out the intake air temperature sensor is built into the Boost Pressure Sensor mounted in the (Intercooler). I hope this helps someone else that has a intake air temperature sensor problem.
Old Jun 10, 2017 | 02:19 PM
trudell17's Avatar
I have a 2004 Volvo xc90 tc6 awd . When I press the gas it pulses and it doesn't go past 40mph
Old Jun 11, 2017 | 09:46 AM
Montyhaul's Avatar
Does your check engine light flash when you try to accelerate? If it does it could be a bad coil pack. That's what mine did, it was an easy fix
thegazelle
Jun 27, 2019 08:24 PM
andysvolvo
Sep 10, 2012 07:52 AM
rquinonez32
Sep 30, 2008 02:08 PM
Maruccio
Jun 9, 2008 05:48 PM
