Console Auxilary Jack
I had a similar problem, luckily the cable was just bad. If you are one hundred percent sure its a good cable here is a trouble shoot. Turn up the stereo all the way. Turn the phone or MP3 player up all the way. Slowly plug into the port. When the tip of the plug is passing by the first connection either the right or left side only should put out some noise. When the plug is in all the way both should work. Good luck, to be sure I would buy a new cable
