Console Auxilary Jack
Old May 4, 2014 | 03:15 PM
REG44's Avatar
Default Console Auxilary Jack
I have a 2009 Volvo XC90 and the auxiliary jack do not work. I am looking for a replacement. any idea other than the dealer to get one?
Old Jun 11, 2014 | 08:41 PM
Stratoblaster's Avatar
I had a similar problem, luckily the cable was just bad. If you are one hundred percent sure its a good cable here is a trouble shoot. Turn up the stereo all the way. Turn the phone or MP3 player up all the way. Slowly plug into the port. When the tip of the plug is passing by the first connection either the right or left side only should put out some noise. When the plug is in all the way both should work. Good luck, to be sure I would buy a new cable
Old Jun 16, 2014 | 09:06 AM
schumicat's Avatar
it uses a unique plug into the factory harness. only the dealer or one of the online dealer parts depts. will likely have it.
Old Oct 22, 2017 | 09:21 PM
virtualbong's Avatar
Bringing this back from the dead. I just purchased an 07 XC90 and the auxiliary jack is messed up. I think this is the issue...only the left side is working and the right side just has a buzz. Does anyone have any idea how much to fix/replace this piece? Is this a DIY job that I can take on?
LiteWait
Mar 14, 2015 07:13 PM
Ghost Brick
Oct 8, 2010 10:17 PM
bw77
Apr 22, 2009 08:28 PM
brianet
Aug 9, 2008 07:32 PM
dan finch
Mar 29, 2006 06:48 PM
