Drivers side rear window
Old Aug 19, 2013 | 12:37 PM
Divincem's Avatar
Default Drivers side rear window
We just had the CEM along with 16 relays replaced in our 2004 XC90 T6. Now mysteriously the rear passenger window can be put down with the driver control switch, but will not go back up. It must be put up with the back passenger window switch. Could it be related to the replacement of the CEM or relays, or just a faulty switch in the drivers side door panel? I'm sure it would be helpful if you knew what relays that were replaced, all I can say is that they were in/near the CEM, drivers side foot kick guard I'm guessing its referred to. Thanks for any thoughts!
Old Aug 25, 2013 | 03:15 PM
epereira's Avatar
recommend replacing the window control module..
Old Aug 25, 2013 | 04:45 PM
schumicat's Avatar
i would test the driver switch. someone with a little knowledge should be able to swap it with one of the other switches to see if it is the problem or test it with a multimeter.
trans am
May 18, 2011 06:53 PM
fish1963
Dec 2, 2010 08:39 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
cdurnal
Nov 18, 2008 07:23 PM
robber
Dec 16, 2007 11:11 AM
