Fan on after engine shutoff
Standard feature called AfterBlow designed to dry out the evaporator and ducting to prevent corrosion and mold. It may cycle on/off several times for as long as an hour+ after the car is turned off. It also monitors battery voltage so as to not run the battery down. Nothing to do. Just let it do its thing.
There are 3 basic benefits to that panel. Better aerodynamics for better fuel economy and it catches minor fluid leaks so you don't leave spots on the garage floor or driveway. It also ties in some of the other plastic panels/shrouds and holds it all together. Best if it is left in place.
MSLamb5
07-05-2009 10:50 PM
