Gearshift knob - What am I doing wrong?
Old Jul 17, 2014 | 07:50 PM
slc10844's Avatar
Default Gearshift **** - What am I doing wrong?
2014 XC90 and decided to replace the shift **** with one that is leather. Researched and it appears to be a simple procedure. No tools required and only four easy steps. Should only take a couple of minutes to complete. Problem starts with step #1. "Loosen the gaiter from the gear lever **** by turning the lock ring on the inside 1/4-turn, and pull down the gaiter." After a half hour of trying I still can't get the lock ring to rotate. Instructions indicate CCW rotation. Tried both ways. Even tried, gently, using a pair of pliers. Will not budge. Am I doing something wrong or is the 2014 different from previous models?
BennyMG
Jan 25, 2017 07:04 PM
shawnjonesec
Feb 3, 2014 12:21 PM
salsabarrios
Aug 10, 2012 01:38 PM
RGT
Sep 17, 2009 05:16 AM
