Guys, help!
Old Aug 19, 2010 | 01:08 PM
cheetah's Avatar
Default Guys, help!
What is the proper name (and part number) of the small hose, that begins near oil cap and goes, somewhere down. Mine is broken and I believe it needs to be replaced. Thank you much!
2005 XC90 2.5T
Old Aug 20, 2010 | 07:13 AM
capsfan69's Avatar
Picture? Sounds like it's part of the PCV system. Check part "A" here to see if it's the same thing.
http://www.ipdusa.com/Volvo-XC90/Eng...-598-926-4738/
Old Aug 20, 2010 | 07:22 AM
cheetah's Avatar
That's it! Thank you!
Old Sep 11, 2010 | 09:06 PM
boyblakester's Avatar
Mine just broke as of today So annoyed. Cheetah did you was it hard to replace?
Old Sep 14, 2010 | 06:40 PM
cheetah's Avatar
Sorry for the delay.
The fix is very, very easy.
1. Buy the right hose replacement. I bought original volvo for some $25.
2. Unscrew both black covers (mine are black) near oil cap.
3. Unscrew two torxes holding a pipe going above the crankshaft (poor idea of placing it there anyway...). This will help you get all the screws. But move that pipe GENTLY, its for the turbo and you dont want to breake it.
4. Remove hose clamps and replace the hose.
5. You may install a new clamps, especially by the oil separator trap. I understand the pressure in that hose is slightly higher than atmospheric, so I didnt bother with putting new clamps. But you may. The one by the trap you may acces with you right hand and a longer screwdriver.
Take a look on the links I placed below. And let me know how did it go.
http://forums.swedespeed.com/showthr...-a-little-help.
http://www.ipdusa.com/Volvo-XC90/Fil...-598-926-4738/
mark850t
Jan 25, 2009 10:05 AM
wheelsup
Jan 8, 2009 08:34 AM
hellion_79
Oct 6, 2007 12:52 PM
proper
Aug 25, 2007 02:05 AM
jiggadude
May 26, 2007 06:29 AM
