Hallogen to Xenon
Old Dec 4, 2023 | 12:40 AM
slider's Avatar
Default Hallogen to Xenon
Hi everyone sorry if asked before, i have an xc90 from 2004 with h7 lamps, is it possible to (plug and play) switch too Xenon lamps from a 2007 xc90? there is a set online which i want to buy just not sure if it will function in my car.
Old Dec 4, 2023 | 07:43 AM
You will get a low beam failure warning (due to different current usage) and the high beams probably won't work. High beams use the inner bulbs with the H7 setup and use an electric motor to aim the HID beam further down the road with the other. Also the HIDs are self leveling (required when car was built.) Your car does not have the hardware/wiring for that - although you can manually adjust the headlamps to a "good enough, I'm only blinding people sometimes" position.
For software to make this work - you would probably have to change the CEM. There won't be a simple "software update" (can you purchase a VIDA subscription in your country?)
Jonathan Jeffreys
Feb 21, 2017 04:05 AM
boss151
Apr 15, 2012 10:51 PM
boss151
Apr 14, 2012 05:52 PM
craigtfromatl
Aug 2, 2010 09:53 AM
ORC
Dec 30, 2009 06:10 PM
