Hello - ON call in standby - Reset help!
Old Jun 6, 2022 | 08:21 AM
JCvxc90's Avatar
Default Hello - ON call in standby - Reset help!
Hello all!
I hope you are well. I recently picked up a lovely 2006 xc90 D5 185.
Everything worked fine until my toddler decided to press the red SOS button and next thing I was being asked what emergency serviced i wanted!!
After an embarrasing call and we hung up.. I then got a message saying this (see photo below).. I now cannot change the station on my radio.. nor can I use the volumes on my steering wheel.
More annoyingly... the lights on the centre console will not go off .. they are permanently on even when car is off and locked.
Anyone know how to reset or get rid?
If there is a subscription to oncall active its not mine it must have been from a previous owner who i do not know who it is.
Thank you
Old Jun 6, 2022 | 10:42 AM
The standby mode is a power saving feature that gets enabled when the car hasn't been driven for 5 days (otherwise powering the modem will drain the battery). It should reset once the car is driven for a short while. If that doesn't reset, try resetting the security system by locking/unlocking the car 5x with the fob or keys then go for a drive.
Old Jun 6, 2022 | 10:57 AM
JCvxc90's Avatar
Thank you for this! ill give it a go...
Very strange as its def been used .. done nearly 600 miles in the past 3 days! all the lights on the center console / phone radio buttons stay on.. hopefully that doesn't drain the battery . That didnt happen before the code appeared
i did try and disconnect the battery for 20 mins but that didn't help.
Ill try and reset the security..
Old Jun 6, 2022 | 02:56 PM
only other thing I can think of is that you no longer have wireless service. In the US, the older cars with On Call uses a 3G modem and those networks have been decomm'd in favor of 4G which requires a modem upgrade. Not sure if Europe and other markets have the same issue.
Old Jun 6, 2022 | 03:46 PM
JCvxc90's Avatar
yes I think thats whats happened.. but funny it was all working fine until the on call /sos button was pressed.
For now I've ended up pulling out the phone fuse and low and behold, all the radio functionalities work as normal... as soon as I put the fuse back I thr message reappears and I lose radio functioning again.
Old Dec 1, 2022 | 11:01 PM
Luiz Fernando Cecilio's Avatar
Default https://youtu.be/JC7ijAQ4hYA
Originally Posted by JCvxc90
Hello all!
Thank you
dan28
Jun 9, 2009 07:16 AM
bill70
Mar 15, 2009 01:11 PM
jkane
Jan 6, 2009 01:21 PM
FDNY112
Dec 23, 2008 11:18 AM
Mullica1771
Jan 30, 2007 10:32 PM
