Help! Broken Dipstick
Old Aug 1, 2011 | 01:53 PM
freshy's Avatar
Default Help! Broken Dipstick
So I went to check the oil on my wife's XC90 yesterday. When I pull on the dipstick the top comes off, but the metal stick stayed down in the tube. I tried grabbing it with tweezers put only managed to push it down further. Any ideas on a solution?
Thanks in advance.
Old Aug 1, 2011 | 02:21 PM
04XC90T6AWD's Avatar
Thanks in advance.
try sucking it out with a shop vac if that doesn't work drop the oil pan.
Old Aug 1, 2011 | 02:44 PM
aprotec58's Avatar
Default dipstick
Really? Drop the oil pan? What about working the end of the tube loose with a small pair of vice-grips until the tube comes loose from the top of the block? Then you can easily remove the stick and replace with another.
Old Aug 1, 2011 | 03:05 PM
bmoore's Avatar
That's a terrible troll.
Old Aug 1, 2011 | 08:33 PM
stonepa's Avatar
aprotec - you are correct.
Old Aug 2, 2011 | 10:38 AM
also i mis understood what he said i thought he meant a small piece broke off sorry sometimes i dont read things thoroughly
Old Aug 2, 2011 | 11:44 AM
agardner's Avatar
So you gave a response without reading the problem? That's scary, dangerous and rude. Thanks for your input!
Old Aug 4, 2011 | 01:58 PM
freshy's Avatar
Thanks aprotec58. Just so I'm clear though. I first need to unscrew the small bolt firmly securing the dipstick tube to the block, then jiggle & pull on the tube and it will detach? Is it going to be able to just slide back into it's original position when I attempt to put it back after removing the metal part of the dipstick? I can't see where it fits into the block at it's insertion point and i didn't want to snap it off.
Thanks!
Old Aug 5, 2011 | 09:37 AM
aprotec58's Avatar
Default dipstick
To be quite honest, Freshy, I haven't actually followed the oil tube to it's ending position, however, any vehicle domestic or foriegn would end at the block just before entering the oil pan. So to answer your question, yes the tube should just easily re-install into the block., then reattach the bolt hold the tube in place.
Old Sep 11, 2011 | 06:58 PM
freshy's Avatar
Thanks for the help. I actually just got around to fixing it this weekend. Unscrewed the fastening bolt at the top of the dipstick oil tube and then wiggled & jiggled it back and forth and it popped right out of the housing down by the block. There was a little rubber gasket(?) that helped keep it secure in the housing, and it easily popped right back in. Took all of about 10 minutes to get the broken dipstick out and everything back together. MUCH easier than trying to blow/suck or tweeze the dipstick out! Thanks for the tip!
Old Sep 13, 2011 | 05:59 AM
gshadow325's Avatar
late to the party but your end result was correct. i would have changed the oring at the end of that tube since it tends to leak there on the volvos. less than a buck. its a easy fix. sometimes people get frustrated and push the tube in wrong and crush the o ring and it develops a leak from there.
Volvoguy505
Jun 6, 2018 03:10 PM
bcolins
2001-2013 model year V70
Oct 28, 2013 10:55 AM
VolvoXC90Car
Aug 24, 2011 07:34 AM
2001s60
Mar 27, 2010 06:17 AM
slance66
Feb 4, 2008 06:01 PM
