Engine oil dipstick is broken off. Is there a known method to get it out of the tube
Old Oct 7, 2013 | 09:03 AM
bcolins's Avatar
Default Engine oil dipstick is broken off. Is there a known method to get it out of the tube
2003 V70XC. (New to me). The engine oil dipstick handle is broken off, and the remainder of the plastic handle is down in the dipstick tube,...about 1" down with the dipstick attached. Thinking I will drill it and insert a self tapping screw into the hole to pull it out,....but I'm a little concerned about plastic bits from the drilling ending up in the oil.
I'm guessing this is not an uncommon problem, so, thought I would check here to see if there is a recognised extraction method.
Brian in Austin
Old Oct 7, 2013 | 09:27 AM
Hi Brian, if you can't get it with needle nose pliers, take the tube out of the motor. It has 1 bolt that holds it in. The other end of it is out of the tube, you can push it out from there.
Old Oct 7, 2013 | 09:41 AM
bcolins's Avatar
Saw the bolt and dipstick tube bracket, was tempted to pull it, but thought I should check here first.
I'll give it a shot.
Brian.
Old Oct 27, 2013 | 09:28 PM
threevolve's Avatar
Pick up one of these:
Amazon.com - Flexible Claw Pick Up Tool Automotive Mechanic Shop 24" Amazon.com - Flexible Claw Pick Up Tool Automotive Mechanic Shop 24"
It will come in handy for all sorts of "oops"
Old Oct 27, 2013 | 10:46 PM
bcolins's Avatar
Brian.
I pulled the tube out when I was replacing my cooling fan, was able to push the broken dipstick out. Currently covered with aluminum foil (several layers thick) wire tied on until I find time to head to the dealer to pick up the new dipstick.
Old Oct 28, 2013 | 10:55 AM
habbyguy's Avatar
Got one delivered to my door for $10.60 from an Ebay vendor. There really isn't much to a dipstick, other than making sure the new one reads the same as the old one (which I did when I swapped it). Hardly worth driving to a dealer (much less paying dealer prices for a dipstick). I'm sure the forum sponsors have other options as well (no doubt cheaper than dealer prices as well).
pyro71
Jun 21, 2014 07:03 PM
98_V70_T5
Jul 1, 2012 11:41 AM
sly_fox
Nov 17, 2011 09:53 AM
crashin
May 24, 2010 04:56 PM
