HELP with front lower side engine mount
Old Jan 1, 2023 | 10:51 PM
Chasboro's Avatar
Default HELP with front lower side engine mount
I have a 2007 XC90 3.2L with 160,000 miles on it. I've been replacing all the engine mounts and need some advice for removing the right front lower engine mount. The large bolts (17mm) going into the frame I can't budge.
Anybody have success on removing those bolts (17mm)? The 13mm ones attaching to the engine are a piece o' cake. I really don't want to remove the axle shaft. It looks like it should be possible without doing that. Just can't break those two bottom bolts loose.
this is the engine mount I'm referring to.
Ideas anyone?? Getting ready to take it to a shop and have some one else do it.
Old Jan 5, 2023 | 01:21 PM
Chasboro's Avatar
I take it by getting no replies no one has done this themselves, which is probably the same route I will go.
vove
Aug 10, 2022 10:59 AM
xDread92x
Nov 5, 2014 09:14 AM
toaoemerald
Jan 24, 2012 11:24 PM
ludeless
May 18, 2011 03:49 PM
rmjryost
Nov 14, 2009 03:07 PM
