HID lights Canbus-ballast constant failure
Old Oct 17, 2014 | 05:10 AM
pancho's Avatar
Default HID lights Canbus-ballast constant failure
Greetings fellow XC-9r's,
My son took my XC-90 , 2004 , to get HID installed on my "low-beams",
for my Birthday , ' but' the Ballasts "Canbus" supposedly the " Better if not the " best",the Shop says "doesn't know the reason.
They installed a "relay-kit" to fix, but still "replac'n them 2 a week.
Luckily, the Shop warranties the Ballasts, but I'm sure "not for very long"
So far 12 have been replaced, I also had the "fog-lites" replaced with a -
matching type of "lite" and had 2 " light-strips" installed in the 2 "vent type-
openings" in front, and the also replaced the "white light " in the Light-housing,also with a "same type of light" . Must admit 8 lights"in front"
looks awsome, but I'm sure , no reason for Ballast-failure, Any Ideas any-one?
Old Oct 17, 2014 | 06:31 AM
ES6T's Avatar
So this is an aftermarket kit? 8 lights in front? Sounds tacky in my opinion.
Old Oct 18, 2014 | 07:58 AM
Vida's Avatar
If you're worry about hitting a moose or keep on replacing the ballasts. I rather hit the moose. :P Aftermarket HID Kits doesn't go very well with these cars, like aftermarket remote starts. Though it can be possible, it's a matter doing your research. I won't be able to tell you because it's too long to write it down, and I can only write small paragraphs. :P
Old Oct 19, 2014 | 03:44 AM
pancho's Avatar
Default HID failure
Thanks to all on reply's,
I know there must be a "remedy" ,maybe find'n someone w/ the same-
problem or that"knows" of this problem.
8 lights that "look" HID are great and get compliments and makes my -
O'l ,2004 " look current.
The HID kit was only for the "low-beams",
The 2 LED lite-strips were installed the the XC,vent looking deals below-
the Lights.
The Fog-lite bulbs were replaces with LED's
And the Plastic Light enclosures"housing the high and low beams" has a -
White-lite "factory made" next to the Park'nlites, also LED white.
And w/ the Volvo Custom Bra , all looks good, I think better than the -
BMW's and Mercedes's "lite-show" I get noth'n but compliments.
I keep it clean and purdy, gett'n gas the other-day and behind an '07-
XC, and they thought mine was " newer", no, I tell'em, just and 'ol 04.
Any thanks all and maybe someone,someday might have a remedy.
schannell
Feb 17, 2020 02:47 PM
Nilfisk2000
May 1, 2013 10:07 AM
gsonn
Mar 5, 2012 01:36 AM
Aty01
Nov 10, 2011 01:16 PM
S60Rob
May 24, 2011 06:10 PM
